[fusion-users] RE: Fusion: calling custom search widget
BTenBroeck billtenbroeck at gmail.com
Thu May 19 15:31:59 EDT 2011
Warren, did you ever get an answer to this? I can only seem to figure out the
syntax if the Widget is the same name as the container (eg <DIV id="Pan" />)
, the I get an object. But once it's inside a container (eg <DIV
id="Toolbar1">), then I can't seem to get a handle on the embedded widget
(Say Pan inside ToolBar1).  I know this has to be beginner question, but I
don't seem to be able to find the solution.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-calling-custom-search-widget-tp5260936p6383417.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
