[fusion-users] Embedding widgets in a non-Fusion container causing
odd behavior
BTenBroeck
billtenbroeck at gmail.com
Thu May 19 15:42:37 EDT 2011
Hello. I have a Telerik toolbar that I am trying to embed Fusion Widgets in.
Most of them work fine by using the activate()/decativate() calls.
However, Pan, Select and Zoom Window seem to be leaving some residual
settings in place, even if I do a Widget.Deactivate(). For instance, if I
select Pan, use it, then select Zoom Window, the initial cursor changes, but
once you hold the mouse button down, the icon switched to a hand, and you
are still in Pan mode.
Is there a method that I could use that would reset all back to original
state? I thought Deactivate would do just that, but it seems to be leaving
some unwanted settings in place.
Thanks in advance,
Bill
PS. This is the version of Fusion from MGE 2007.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Embedding-widgets-in-a-non-Fusion-container-causing-odd-behavior-tp6383453p6383453.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
