[fusion-users] Query by attributes
Michael Adair
madair at dmsolutions.ca
Wed Nov 16 16:36:07 EST 2011
You can use the SelectAttribute widget. The config is like so:
<Widget>
<Name>QueryByAttribute</Name>
<Type>SelectAttribute</Type>
<ImageUrl>images/icons.png</ImageUrl>
<ImageClass>select-attribute</ImageClass>
<Label>Select by Attribute</Label>
<Tooltip>Query features by attributes</Tooltip>
<Extension>
<Container>QueryParams</Container>
</Extension>
</Widget>
where <Container> is an element in the HTML to contain the drop downs
and form elements for the widget.
Mike
On 16/11/2011 4:30 PM, jbogdani wrote:
> Hello all,
> my question is: is there any configurable widget available in fusion that I
> can use to make queries (selects) on features using their attributes?
> Eventually anybody has documentation / case studies to share about this?
> Thank you
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Query-by-attributes-tp7001936p7001936.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
