[fusion-users] Query by attributes
Julian Bogdani julian.bogdani at unibo.it
Mon Nov 21 15:23:00 EST 2011
Hello,
I'm probably missing something.
Adding this widget to the Application Definition file produces an error: 404 Not Found - http://localhost/gis/fusion/widgets/SelectAttribute.js"
That's because  the widget is not available in my installation. Did I download on old fusion version or should I implement the widget by myself?
In this second case I'm afraid I'm not able to build it and I'm looking for a (almost)ready-to-use example :)
Maybe this is one: http://trac.osgeo.org/fusion/wiki/HowToCreateWidget ?
Julian
Begin forwarded message:
> From: Michael Adair <madair at dmsolutions.ca>
> Date: November 16, 2011 10:36:07 PM GMT+01:00
> To: fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] Query by attributes
> You can use the SelectAttribute widget.  The config is like so:
> <Widget>
> <Name>QueryByAttribute</Name>
> <Type>SelectAttribute</Type>
> <ImageUrl>images/icons.png</ImageUrl>
> <ImageClass>select-attribute</ImageClass>
> <Label>Select by Attribute</Label>
> <Tooltip>Query features by attributes</Tooltip>
> <Extension>
> <Container>QueryParams</Container>
> </Extension>
> </Widget>
> where <Container> is an element in the HTML to contain the drop downs and form elements for the widget.
> Mike
> On 16/11/2011 4:30 PM, jbogdani wrote:
>> Hello all,
>> my question is: is there any configurable widget available in fusion that I
>> can use to make queries (selects) on features using their attributes?
>> Eventually anybody has documentation / case studies to share about this?
>> Thank you
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Query-by-attributes-tp7001936p7001936.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20111121/fb9de8fb/attachment.html
More information about the fusion-users mailing list
