[fusion-users] Query by attributes
Michael Adair
madair at dmsolutions.ca
Mon Nov 21 16:08:49 EST 2011
Julian,
Yes I think that widget was added in the 2.2 release so you will need to
use that version for sure. And I'm afraid that 'How to Create a Widget'
has some correct sections in it but others are out of date, so your best
bet for an example is to look at real code. Find a widget that has the
chrome behaviour you want (button, panel, dialog, etc.) and try to
follow one of those.
Mike
On 21/11/2011 3:23 PM, Julian Bogdani wrote:
> Hello,
> I'm probably missing something.
> Adding this widget to the Application Definition file produces an
> error: 404 Not Found -
> http://localhost/gis/fusion/widgets/SelectAttribute.js"
> That's because the widget is not available in my installation. Did I
> download on old fusion version or should I implement the widget by myself?
> In this second case I'm afraid I'm not able to build it and I'm
> looking for a (almost)ready-to-use example :)
> Maybe this is one: http://trac.osgeo.org/fusion/wiki/HowToCreateWidget ?
> Julian
> Begin forwarded message:
>> *From: *Michael Adair <madair at dmsolutions.ca
>> <mailto:madair at dmsolutions.ca>>
>> *Date: *November 16, 2011 10:36:07 PM GMT+01:00
>> *To: *fusion-users at lists.osgeo.org <mailto:fusion-users at lists.osgeo.org>
>> *Subject: **Re: [fusion-users] Query by attributes*
>> You can use the SelectAttribute widget. The config is like so:
>> <Widget>
>> <Name>QueryByAttribute</Name>
>> <Type>SelectAttribute</Type>
>> <ImageUrl>images/icons.png</ImageUrl>
>> <ImageClass>select-attribute</ImageClass>
>> <Label>Select by Attribute</Label>
>> <Tooltip>Query features by attributes</Tooltip>
>> <Extension>
>> <Container>QueryParams</Container>
>> </Extension>
>> </Widget>
>> where <Container> is an element in the HTML to contain the drop downs
>> and form elements for the widget.
>> Mike
>> On 16/11/2011 4:30 PM, jbogdani wrote:
>>> Hello all,
>>> my question is: is there any configurable widget available in fusion
>>> that I
>>> can use to make queries (selects) on features using their attributes?
>>> Eventually anybody has documentation / case studies to share about this?
>>> Thank you
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/Query-by-attributes-tp7001936p7001936.html
>>> Sent from the Fusion Users mailing list archive at Nabble.com
>>> <http://Nabble.com>.
>>> fusion-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20111121/b046fd54/attachment.html
More information about the fusion-users
