[fusion-users] Known problems with mapserver 5.6.6-6
jbogdani jbogdani at gmail.com
Sun Nov 20 09:07:57 EST 2011
Hello list,
I've a working Fusion installation that gets geo-data from a mysql database.
1) My server configuration (working fine) is the following:
Ubuntu server 10.04.03
Apache 2.2.14
MySQL 5.1.41
PHP 5.3.2-1ubuntu4.10
MapServer 5.6.1 with Mapscript installed
2) But I had serious problems setting on a second server using the following
configuration:
Ubuntu 11.10
Apache 2.2.20
MySQL 5.1.58
PHP 5.3.6-13
MapServer 5.6.6
Using the same geo data & the same mapfiles I can see the map but I can
select no feature! Firebug reports the following errors:
"NetworkError: 500 Internal Server Error -
http://localhost/gis/fusion/layers/MapServer/php/Query.php"
Apache log reports:
[Sun Nov 20 15:03:12 2011] [error] PHP Warning:  [MapServer Error]:
msQueryByPoint(): No matching record(s) found.\n in
/home/webgis/www/fusion/layers/MapServer/php/Query.php on line 213
msLoadMap(): Parsing error near (ENDa):(line 367)\n in
[Sun Nov 20 15:03:12 2011] [error] PHP Fatal error:  [MapServer Error]:
/home/webgis/www/fusion/layers/MapServer/php/Query.php on line 270
Working with shapefiles everything seems to work fine. Is it a Fusion
problem, a Mapserver / mapscript problem, or what?
3) Finally no map is shown if Mapserver 6 is installed in the same server
(no. 2). Has Fusion been tested with Mapserver 6.x?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Known-problems-with-mapserver-5-6-6-6-tp7013710p7013710.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
