[fusion-users] Known problems with mapserver 5.6.6-6
Paul Spencer
pspencer at dmsolutions.ca
Mon Nov 21 08:39:55 EST 2011
The likely suspects are usually the PHP and mapserver versions, both could cause problems.
Just to be sure, have you run shp2img on your map file to ensure that its not some subtle mapfile syntax change that is biting you? I'd say that in general Fusion should work with 6.0 but I don't think anyone else has tried it yet. I'm not sure that there were any API changes in PHP mapscript, it is possible.
Cheers
Paul
On 2011-11-20, at 9:07 AM, jbogdani wrote:
> Hello list,
> I've a working Fusion installation that gets geo-data from a mysql database.
> 1) My server configuration (working fine) is the following:
> Ubuntu server 10.04.03
> Apache 2.2.14
> MySQL 5.1.41
> PHP 5.3.2-1ubuntu4.10
> MapServer 5.6.1 with Mapscript installed
> 2) But I had serious problems setting on a second server using the following
> configuration:
> Ubuntu 11.10
> Apache 2.2.20
> MySQL 5.1.58
> PHP 5.3.6-13
> MapServer 5.6.6
> Using the same geo data & the same mapfiles I can see the map but I can
> select no feature! Firebug reports the following errors:
> "NetworkError: 500 Internal Server Error -
> http://localhost/gis/fusion/layers/MapServer/php/Query.php"
> Apache log reports:
> [Sun Nov 20 15:03:12 2011] [error] PHP Warning: [MapServer Error]:
> msQueryByPoint(): No matching record(s) found.\n in
> /home/webgis/www/fusion/layers/MapServer/php/Query.php on line 213
> msLoadMap(): Parsing error near (ENDa):(line 367)\n in
> [Sun Nov 20 15:03:12 2011] [error] PHP Fatal error: [MapServer Error]:
> /home/webgis/www/fusion/layers/MapServer/php/Query.php on line 270
> Working with shapefiles everything seems to work fine. Is it a Fusion
> problem, a Mapserver / mapscript problem, or what?
> 3) Finally no map is shown if Mapserver 6 is installed in the same server
> (no. 2). Has Fusion been tested with Mapserver 6.x?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Known-problems-with-mapserver-5-6-6-6-tp7013710p7013710.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20111121/e7e1ce56/attachment.html
More information about the fusion-users
