[fusion-users] Known problems with mapserver 5.6.6-6
Michael Adair madair at dmsolutions.ca
Mon Nov 21 10:06:57 EST 2011
I did a quick trial of  Fusion with MapServer 6 and it appears that the
underlying Mapscript objects have changed so Fusion PHP code needs to be
fixed for MapServer 6.  I wouldn't go down that route yet.
It's hard to say what the issue is without seeing the site, but I would
focus on the "parsing error" in your stack trace.
Mike
On 21/11/2011 8:39 AM, Paul Spencer wrote:
> The likely suspects are usually the PHP and mapserver versions, both
> could cause problems.
> Just to be sure, have you run shp2img on your map file to ensure that
> its not some subtle mapfile syntax change that is biting you?  I'd say
> that in general Fusion should work with 6.0 but I don't think anyone
> else has tried it yet.  I'm not sure that there were any API changes
> in PHP mapscript, it is possible.
> Cheers
> Paul
> On 2011-11-20, at 9:07 AM, jbogdani wrote:
>> Hello list,
>> I've a working Fusion installation that gets geo-data from a mysql
>> database.
>> 1) My server configuration (working fine) is the following:
>> Ubuntu server 10.04.03
>> Apache 2.2.14
>> MySQL 5.1.41
>> PHP 5.3.2-1ubuntu4.10
>> MapServer 5.6.1 with Mapscript installed
>> 2) But I had serious problems setting on a second server using the
>> following
>> configuration:
>> Ubuntu 11.10
>> Apache 2.2.20
>> MySQL 5.1.58
>> PHP 5.3.6-13
>> MapServer 5.6.6
>> Using the same geo data & the same mapfiles I can see the map but I can
>> select no feature! Firebug reports the following errors:
>> "NetworkError: 500 Internal Server Error -
>> http://localhost/gis/fusion/layers/MapServer/php/Query.php"
>> Apache log reports:
>> [Sun Nov 20 15:03:12 2011] [error] PHP Warning:  [MapServer Error]:
>> msQueryByPoint(): No matching record(s) found.\n in
>> /home/webgis/www/fusion/layers/MapServer/php/Query.php on line 213
>> msLoadMap(): Parsing error near (ENDa):(line 367)\n in
>> [Sun Nov 20 15:03:12 2011] [error] PHP Fatal error:  [MapServer Error]:
>> /home/webgis/www/fusion/layers/MapServer/php/Query.php on line 270
>> Working with shapefiles everything seems to work fine. Is it a Fusion
>> problem, a Mapserver / mapscript problem, or what?
>> 3) Finally no map is shown if Mapserver 6 is installed in the same server
>> (no. 2). Has Fusion been tested with Mapserver 6.x?
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Known-problems-with-mapserver-5-6-6-6-tp7013710p7013710.html
>> Sent from the Fusion Users mailing list archive at Nabble.com
>> <http://Nabble.com>.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org <mailto:fusion-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
> http://research.dmsolutions.ca/
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20111121/81cc44c5/attachment.html
More information about the fusion-users mailing list
