Use of 'errno' in example
Aleksey naumov at a...
Fri Dec 14 12:44:39 EST 2001
Frank,
I have a small question on the use of 'errno' variable in the documentation
for the CPLSetErrorHandler() -- it isn't the 'errno' defined in errno.h, is
it?
If it isn't, maybe change the name in documentation? It's a small
inconsistency but would prevent a compiler error as a result of copy & paste
from there (that's what I did for my error handling function)? Maybe change
to 'err_no' as in CPLError in cpl_error.h?
Thanks,
Aleksey
>From cpl_error.cpp:
* CPLSetErrorHandler()
* Install custom error handler.
* Allow the library's user to specify his own error handler function.
* A valid error handler is a C function with the following prototype:
* <pre>
* void MyErrorHandler(CPLErr eErrClass, int errno, const char *msg)
* </pre>
