[gdal-dev] arc/info binary grids / mapserver
Frank Warmerdam warmerdam at p...
Fri Dec 14 15:33:34 EST 2001
Ian,
I have discovered a problem in the way I was handling the sign of "RMin"
values that were less than 4 bytes long. With this corrected in the code
things work fine. Did you get a pre-built GDAL or build it yourself? If
you built it from cvs just do an update to get the new
gdal/frmts/aigrid/gridlib.c and things should work fine.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
