[gdal-dev] OGRCreateCoordinateTransformation
Frank Warmerdam
warmerdam at p...
Sun Jul 15 23:32:03 EDT 2001
Ben Discoe wrote:
> Is OGRCreateCoordinateTransformation() part of the usual GDAL/OGR library?
> I know that OGR is a "loosely coupled subcomponent" of GDAL, so perhaps it
> omitted? I am linking against gdal_i.lib and it is coming up undefined.
> It looks like it is the only way to convert coordinates, a very important
> ability, so i would hope that it is built in to GDAL somehow.
Ben,
I have apparently never used this function in code outside of the GDAL
DLL before (though I have called the C analog OCTNewCoordinateTransformation())
and so I didn't realize it wasn't properly defined with the CPL_DLL marker
in the include file. I have corrected this. After a clean build it should
be exported properly and available in gdal_i.lib.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
