[gdal-dev] Small build problem
Frank Warmerdam warmerdam at p...
Mon Jul 16 09:18:50 EDT 2001
Ben Discoe wrote:
> I got gdal from cvs and tried to build it on Win32. The library compiled
> nicely, but it snagged on some problem (with the test applications?)
> Creating library gdal_i.lib and object gdal_i.exp
> cd apps
> nmake /f makefile.vc
> NMAKE : fatal error U1073: don't know how to make 'lib\setargv.obj'
> Stop.
Ben,
I imagine you don't have the VCDIR variable set properly in GDAL\nmake.opt.
This tells the system where Visual C++ is found so that it can link against
the wildcard expansion code in $VCDIR/lib/setargv.obj. It may also affect
some other build aspects.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
