[gdal-dev] Re: GDALComputeRasterMinMax DEATH!!!
f fds nakiya123 at y...
Thu Nov 29 22:54:48 EST 2001
Thanks for the quick response!!
Here's a troublesome dem. There's actually 2 in this
tarball, but the one in question is 8112****.DDF.
Thanks
--- Frank Warmerdam <warmerdam at p...> wrote:
> nakiya123 at y... wrote:
> > Also....
> > I just tried gdal_translate on one of these messed
> up dems and it did
> > the same thing:
> > ERROR 3: Data record is short on DDF file.
> > FOR EVER!!! :(
> I would appreciate a sample. While I can't make the
> file work if it is
> corrupt, I would at least like to make the library
> code more bulletproof
> so it recovers gracefully and reports an error.
> Best regards,
> I set the clouds in motion - turn up | Frank
> Warmerdam, warmerdam at p...
> light and sound - activate the windows |
> http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
__________________________________________________
Do You Yahoo!?
Yahoo! GeoCities - quick and easy web site hosting, just $8.95/month.
http://geocities.yahoo.com/ps/info1
Type: application/x-tar
Desc: canton.tar
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20011129/c2db8ce3/canton.tar
