[gdal-dev] Re: trying to get lat/lon out of sdts dem
    Frank Warmerdam
    warmerdam at p...
    Tue Oct 23 18:05:30 EDT 2001
nakiya123 at y... wrote:
> double dfGeorefX=0.0, dfGeorefY=0.0;
I think the above line is your problem. You are starting with
a dfGeorefX and dfGeorefY of (0,0), which is the bottom left corner
of the UTM zone. You need to set the initial dfGeorefX and dfGeorefY
values based on the GeoTransform as I showed in my email. Note that
the OGRCoordinateTransformation is only used to transform a correct
UTM coordinate to lat/long. It doesn't know anything about how to
determine the original utm coordinates.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
