trying to get lat/lon out of sdts dem
nakiya123 at y...
nakiya123 at y...
Tue Oct 23 18:10:32 EDT 2001
--- In gdal-dev at y..., Frank Warmerdam <warmerdam at p...> wrote:
> nakiya123 at y... wrote:
> > double dfGeorefX=0.0, dfGeorefY=0.0;
> I think the above line is your problem. You are starting with
> a dfGeorefX and dfGeorefY of (0,0), which is the bottom left corner
> of the UTM zone. You need to set the initial dfGeorefX and dfGeorefY
> values based on the GeoTransform as I showed in my email. Note that
> the OGRCoordinateTransformation is only used to transform a correct
> UTM coordinate to lat/long. It doesn't know anything about how to
> determine the original utm coordinates.
> Best regards,
Sorry bout that double posting everyone.
Thanks, that was it.
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
