files remaining open after OGR reads SDTS vectors
bdiscoe ben at v...
Sun Apr 14 21:13:28 EDT 2002
I am attempting to add support for reading SDTS files directly from
their archive, e.g. "FOO.sdts.tar.gz". To do this, my application
expands the archive into a temporary folder, finds the CATD file,
reads the data with OGR, then attempts to delete the temporary files.
However, of the 22 files in my SDTS 'transfer', 8 of them are
refusing to be deleted after OGR has finished reading them:
AHDR.DDF
ARDF.DDF
ARDM.DDF
LE01.DDF
NA01.DDF
NO01.DDF
NP01.DDF
PC01.DDF
I think this is because OGR is forgetting to close the files. As far
i can tell i am doing everything correctly:
OGRDataSource *datasource = OGRSFDriverRegistrar::Open(fname);
// (read the data from the layers)
delete datasource;
Is there something else i need to do so that the files get closed
properly? Or is this a bug?
Thanks,
Ben
