[gdal-dev] files remaining open after OGR reads SDTS vectors
Frank Warmerdam
warmerdam at p...
Mon Apr 15 09:16:37 EDT 2002
bdiscoe wrote:
> I think this is because OGR is forgetting to close the files. As far
> i can tell i am doing everything correctly:
> OGRDataSource *datasource = OGRSFDriverRegistrar::Open(fname);
> // (read the data from the layers)
> delete datasource;
> Is there something else i need to do so that the files get closed
> properly? Or is this a bug?
Ben,
How embarrasing. I have corrected the OGRSDTSTDataSource destructor to
delete the underlying SDTSTransfer object which should correct the problem.
The corrected file (committed to CVS) is ogr/ogrsf_frmts/sdts/ogrsdtsdatasource.cpp.
Thanks for the pointer,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
