[gdal-dev] using GIO driver to create grids
Andrew.Loughhead at c...
Tue Apr 16 19:01:57 EDT 2002
Thanks so much for looking into this Frank, its a relief to
have it confirmed as a bug. I will probably do as you suggest
for the time being.
Andrew
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at p...]
> Sent: Saturday, 13 April 2002 5:54 AM
> To: gdal-dev at yahoogroups.com
> Subject: Re: [gdal-dev] using GIO driver to create grids
> ------------------------ Yahoo! Groups Sponsor
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
> http://us.click.yahoo.com/k6cvND/n97DAA/ySSFAA/E5z3lB/TM
> Andrew,
> Sorry for the delay in getting back to you. I worked on the
> GIO driver a
> bunch last Friday and determined that the WriteGeoreference()
> function is
> corrupting the file (as far as ArcView is concerned anyways).
> I spent quite
> a bit of time with binary dumps of the .hdr files to see what
> all I should
> be changing to update the georeferencing but never quite
> mastered it. I hope
> to try some more but five days have passed without getting
> back to it so I
> thought I should give a status report.
> If you need to create files with the GIO driver you can do it
> by commenting
> out the comments of the georeferencing writing function but
> of course you
> will lose any georeferencing in the produced grids.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at p...
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
