GDAL/OGR 1.1.7 Released
Frank Warmerdam warmerdam at p...
Thu Apr 18 11:12:55 EDT 2002
Folks,
The GDAL/OGR package 1.1.7 release is now available for download in source
format. It can be found at:
ftp://ftp.remotesensing.org/pub/gdal/gdal-1.1.7.tar.gz
ftp://ftp.remotesensing.org/pub/gdal/gdal117.zip
GDAL is a translator library for raster geospatial data formats that
is released under an Open Source license. As a library, it presents a
single abstract data model to the calling application for all supported
formats. The related OGR library (which lives within the GDAL source
tree) provides a similar capability for simple features vector data.
The following entries in the NEWS file cover major changes in 1.1.7.
GDAL 1.1.7 - Overview of Changes
o Add XPM (X11 Pixmap) format.
o Added rough ENVI raster format read support.
o Added --version support (and supporting GDALVersionInfo() function).
o Special hooks for getting raw record data from sar ceos files and Envisat
via the metadata api.
o Upgraded TIFF/GeoTIFF support to CVS version ... includes new extension
API and removes need for private libtiff include files entirely.
o gdal_translate now has scaling option (-scale).
o Added utility documentation.
OGR 1.1.7 - Overview of Changes
o Added Arc/Info binary coverage format read support.
o Added ogrtindex for building MapServer compatible OGR tile indexes.
o Added default implementation of GetFeature(fid) method on OGRLayer.
o Shape driver now supports reading and creating free standing .dbf files
for layers without geometry.
o Fixed major memory/file handle leak in SDTS access.
o Added ADSK_GEOM_EXTENT support for OLE DB provider.
o Ensure shapefiles written with correct polygon ring winding direction
plus various other shapefile support fixes.
o GML read/write working reasonable well, including use of .gfs files.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
