[gdal-dev] Using GRASSDataset
Frank Warmerdam warmerdam at p...
Wed Jan 23 16:36:01 EST 2002
Folks,
Sorry for that last email. I am operating in a new email program this week
as I consider what to use as a new email environment. I am sick of how
miserably slow the Mozilla email tool is on my system.
On Wed, Jan 23, 2002 at 02:23:30PM -0500, Aleksey wrote:
> Band 1 Block=1066x1 Type=Float32, ColorInterp=Gray
> Min=-4294967295.000/0, Max=4294967295.000/0, Computed Min/Max=nan,nan
> [aleksey at botik PERMANENT]$
> GRASS gives me ("r.info"):
> Range of data: min = 344.000000 max = 614.599976
> If this helps, the "t10" dataset was imported into GRASS with "r.in.gdal"
> from a USGS ASCII DEM format that I bugged you about (and you added, thanks!)
> not so long ago.
Getting nan is pretty frightening! Could you tar up the location and mapset
in with this dataset and ftp it to me? I would like do some digging around.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
