[gdal-dev] S-57 Polygon Warning...
Frank Warmerdam
warmerdam at p...
Mon Mar 11 09:17:06 EST 2002
Eric J. Peters wrote:
> Thanks, that was it. I had the 1.1.1.1 revision of ograssemblepolygon. :)
> On another note, the viewer fails to build due to an unsupported function call:
> GDALCreateProjDef. I found this:
> void *GDALCreateProjDef( const char * pszDef )
> CPLDebug( "GDAL", "GDALCreateProjDef no longer supported." );
> return NULL;
> and assume there is replacement code somewhere and a viewer rewrite is in the
> works. Is this a correct assumption? Is there anything I can do to assist in
> getting the viewer to build?
Eric,
The viewer is a defunct effort. I now use OpenEV (openev.sf.net) as my
viewer for most purposes. It includes support for reading using GDAL/OGR.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
