[gdal-dev] Re: OpenEV_FW_1.4.2
Frank Warmerdam warmerdam at p...
Thu May 16 11:33:11 EDT 2002
jlawheadus wrote:
> Frank,
> I downloaded OpenEV 1.4.2 on Windows 2000. I put the correct path to
> the OpenEV directory tree in "setfw.bat" but when I run "openev.bat" I
> get a dialog box from Python with the following error:
> "The procedure entry point NCSFileTellStdIO could not be located in
> the dynamic link library NCSUtil.dll"
> I also have ActiveState's Python version 2.2 installed so I added the
> full path to the Python executable in OpenEV to "openev.bat" just
> to make sure the correct version was used. I still received the same
> error.
> Any ideas?
> Thanks,
> Joel
Joel,
I am unable to reproduce this problem. I would suggest resetting your path
to the minimum before running openev to ensure you aren't getting some other
environment variable, though setfw.bat does try to put the OpenEV_FW bin
directory ahead of everything else so I wouldn't think this would be a problem.
Do you have any NCS dlls in your WINNT or WINNT\SYSTEM32 directories (or
whatever the equivelent directories are on Win2000)? If so, I think they
take precidence over the PATH. Try running OpenEV.bat from within
openev_fw\bin. In that case the local dlls should take precidence over even
the ones in the system directories.
Also, I discovered while looking into this that there is another problem with
using openev in the distribution I posted. Assuming you get past the above
problem, could you try the following dist and see if it is OK for you?
ftp://gdal.velocet.ca/pub/outgoing/OpenEV_FW_143.zip
If so, I will post it in the usual places.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
