OpenEV_FW_1.4.2
jlawheadus jlawhead at p...
Thu May 16 17:50:51 EDT 2002
Good news - a duplicate 'ncsutil.dll' was to blame in my system32
directory as Frank predicted. I forgot I had some other ERMapper
software installed. I renamed the dll in the system32 dir temporarily
and that did the trick.
And the 1.4.3 version works great. I've been playing with it and
haven't run into any trouble yet on Win2k.
Thanks everyone.
-- Joel
--- In gdal-dev at y..., Frank Warmerdam <warmerdam at p...> wrote:
> jlawheadus wrote:
> > Frank,
> > I downloaded OpenEV 1.4.2 on Windows 2000. I put the correct path
to
> > the OpenEV directory tree in "setfw.bat" but when I run
"openev.bat" I
> > get a dialog box from Python with the following error:
> > "The procedure entry point NCSFileTellStdIO could not be located
in
> > the dynamic link library NCSUtil.dll"
> > I also have ActiveState's Python version 2.2 installed so I added
the
> > full path to the Python executable in OpenEV to "openev.bat" just
> > to make sure the correct version was used. I still received the
same
> > error.
> > Any ideas?
> > Thanks,
> > Joel
> Joel,
> I am unable to reproduce this problem. I would suggest resetting
your path
> to the minimum before running openev to ensure you aren't getting
some other
> environment variable, though setfw.bat does try to put the OpenEV_FW
bin
> directory ahead of everything else so I wouldn't think this would be
a problem.
> Do you have any NCS dlls in your WINNT or WINNT\SYSTEM32 directories
(or
> whatever the equivelent directories are on Win2000)? If so, I think
they
> take precidence over the PATH. Try running OpenEV.bat from within
> openev_fw\bin. In that case the local dlls should take precidence
over even
> the ones in the system directories.
> Also, I discovered while looking into this that there is another
problem with
> using openev in the distribution I posted. Assuming you get past
the above
> problem, could you try the following dist and see if it is OK for
you?
> ftp://gdal.velocet.ca/pub/outgoing/OpenEV_FW_143.zip
> If so, I will post it in the usual places.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at p...
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
Rent
