[Gdal-dev] GDAL for PPC Linux
cbsled at ncia.net cbsled at ncia.net
Tue Nov 26 08:53:55 EST 2002
On 11/24/02, at 07:18 PM, "Norman Vine" <nhv at cape.com> said:
>You need to run ldconfig
I added a some directories to /etc.ld.so.conf, then ran ldconfig.
That changed the error, but r.in.gdal still did not run...
So I did in my src/gdal:
    make clean
    ./configure
    make
#(The resulting libgdal.1.1.so is about 3.6MB)
    cp libgdal.1.1.so /usr/local/grass5/lib/
Then, as root:
    ldconfig
r.in.gdal now segfaults.
Suggestions?
Carl Brown cbsled at ncia.net
