[Gdal-dev] GDAL for PPC Linux
Antti.Roppola at brs.gov.au Antti.Roppola at brs.gov.au
Tue Nov 26 21:41:49 EST 2002
You will need to check:
 - What libs (and paths) are used by gdal
	ldd libgdal.1.1.so
 - Check to see if they exist where libgdal thinks they are
 - Check to see if the paths for libgdal and any dependant
   libraries are in ld.so.conf
 - Check GDAL independantly of your app (i.e. use gdalinfo to query a TIFF)
Once we know GDAL is working correctly, *then* troubleshoot your app:
 - Check your application ("r.in.gdal") to see where it thinks
   gdal is located. (I am not using grass, so I'm guessing)
	ldd r.in.gdal
FWIW, the GDAL compile and install has always seemed pretty robust to me.
On my system, "make install" installed to /usr/lib/ by default, not
/usr/local/grass/, maybe check though the GDAL Makefile if there are
other references to /usr/lib?
Cheers,
Antti
-----Original Message-----
From: cbsled at ncia.net [mailto:cbsled at ncia.net]
Sent: Wednesday, 27 November 2002 12:54 AM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] GDAL for PPC Linux
On 11/24/02, at 07:18 PM, "Norman Vine" <nhv at cape.com> said:
>You need to run ldconfig
I added a some directories to /etc.ld.so.conf, then ran ldconfig.
That changed the error, but r.in.gdal still did not run...
So I did in my src/gdal:
    make clean
    ./configure
    make
#(The resulting libgdal.1.1.so is about 3.6MB)
    cp libgdal.1.1.so /usr/local/grass5/lib/
Then, as root:
    ldconfig
r.in.gdal now segfaults.
Suggestions?
Carl Brown cbsled at ncia.net
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
