[gdal-dev] cvs co
Frank Warmerdam warmerdam at p...
Wed Nov 13 15:29:29 EST 2002
April Shimitz wrote:
> Frank,
> For some reason I cannot check out the GDAL source when specifying a tag
> (but when I specify a revision number, it works fine). I can't make much
> sense at all of the output I see when I try to check out the entirety of
> GDAL, but when I attempt to just do an update on a single file and specify
> a tag (i.e. "cvs up -r gdal_1_1_6 configure"), I get the following error:
> cvs [server aborted]: cannot write /cvsroot/CVSROOT/val-tags: Permission
> denied
> This happens both when I login as user "anonymous" and "shimitz". Do you
> have any idea what the problem is?
April,
Could you try again? I have changed the permissions on the val-tags file.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
