cvs co
April Shimitz shimitz at u...
Wed Nov 13 16:10:19 EST 2002
>> Frank,
>> For some reason I cannot check out the GDAL source when specifying a tag
>> (but when I specify a revision number, it works fine). I can't make much
>> sense at all of the output I see when I try to check out the entirety of
>> GDAL, but when I attempt to just do an update on a single file and
specify
>> a tag (i.e. "cvs up -r gdal_1_1_6 configure"), I get the following
error:
>> cvs [server aborted]: cannot write /cvsroot/CVSROOT/val-tags: Permission
>> denied
>> This happens both when I login as user "anonymous" and "shimitz". Do you
>> have any idea what the problem is?
>April,
>Could you try again? I have changed the permissions on the val-tags file.
Frank,
Well, it partially fixed it. Now I can co and do diffs specifying the
gdal_1_1_6 tag, but it still error with any other revision tag. Also, are
you applying a global tag to the code at each major release?
April
