A small enhancement to gt_wkt_srs.cpp
Roger James
rogerjames99 at b...
Wed Oct 2 08:35:59 EDT 2002
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Frank,
I have added the following few lines to gt_wkt_srs.cpp. It seemed a shame n=
ot to take advantage of the EPSG data if it was present. It would be nice i=
f you could include them. The idea could be extended to look for a GEOGCS s=
tring in the same file if the PROJCS one failed.
/* GTIFSetFromOGISDefn() */
/* Write GeoTIFF projection tags from an OGC WKT definition. */
int GTIFSetFromOGISDefn( GTIF * psGTIF, const char *pszOGCWKT )
/* Handle the projection transformation. */
const char *pszProjection =3D poSRS->GetAttrValue( "PROJECTION" );
// RFJ
// Find the EPSG projected cs code from the wkt proj cs name
if (nPCS =3D atoi(CSVGetField( CSVFilename("horiz_cs.csv"),
"HORIZCS_EPSG_NAME", poSRS->GetAttrValue(=
"PROJCS"), CC_ApproxString,
"HORIZCS_CODE")))
GTIFKeySet(psGTIF, ProjectedCSTypeGeoKey, TYPE_SHORT, 1, nPCS );
GTIFKeySet(psGTIF, GTModelTypeGeoKey, TYPE_SHORT, 1, ModelTypeProjected);
else
// RFJ
if( pszProjection =3D=3D NULL )
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20021002/4611f053/attachment.html
