[gdal-dev] A small enhancement to gt_wkt_srs.cpp
Frank Warmerdam
warmerdam at p...
Wed Oct 2 08:52:13 EDT 2002
Roger James wrote:
> Frank,
> I have added the following few lines to gt_wkt_srs.cpp. It seemed a
> shame not to take advantage of the EPSG data if it was present. It would
> be nice if you could include them. The idea could be extended to look
> for a GEOGCS string in the same file if the PROJCS one failed.
Roger,
I agree with the concept and have submitted your suggestion in Bugzilla
as bug 211 (http://bugzilla.remotesensing.org/show_bug.cgi?id=211).
However I would also note:
o If there are EPSG code numbers in the WKT via the AUTHORITY[] mechanism
that should be utilized.
o Even if we write the PCS code I would still like to write out the full
projection parameters.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
