[Gdal-dev] Cygwin CVS errors
Norman Vine
nhv at cape.com
Tue Apr 1 06:26:31 EST 2003
Frank Warmerdam writes:
> Norman Vine wrote:
> > Hi all,
> > Trying to build GDAL CVS today with Cygwin I get the errors below
> > On further investigation I find
> > from ograssemblepolygon.cpp
> > OGRPolygon *OGRBuildPolygonFromEdges( ... )
> > and from ogr_api.h:
> > OGRGeometryH CPL_DLL OGRBuildPolygonFromEdges( ... )
> > Any advice appreciated
> Norman,
> I am not sure why this would have arisen recently, but I have added
> ogr/ograssemblepolygon.o to the list of files forcably included in
> the shared library. This change is in GDALmake.opt.in so you will need
> to update it from CVS, and re-run config.status.
> Let me know if this doesn't resolve the problem.
Frank,
That didn't seem to help, so working on the assumption that this was
just a function signature problem between the 'C' and the 'C++' code
I tried the following patch which seems to work :-)
Not sure if this is the cleanest way todo this but then again
adding a 'C' Interface to a C++ library is sometimes a bit
'tricky' anyway esp with Cygwin Dlls
Cheers
Norman
Index: ograssemblepolygon.cpp
RCS file: /cvsroot/osrs/gdal/ogr/ograssemblepolygon.cpp,v
retrieving revision 1.6
diff -c -w -r1.6 ograssemblepolygon.cpp
*** ograssemblepolygon.cpp 31 Mar 2003 15:55:42 -0000 1.6
--- ograssemblepolygon.cpp 1 Apr 2003 11:14:46 -0000
*** 178,183 ****
--- 178,199 ----
+ CPL_C_START
+ typedef void *OGRGeometryH;
+ OGRGeometryH CPL_DLL OGRBuildPolygonFromEdges( OGRGeometryH
hLinesAsCollection,
+ int bBestEffort,
+ int bAutoClose,
+ double dfTolerance,
+ OGRErr * peErr )
+ OGRBuildPolygonFromEdges( (OGRGeometryCollection *)hLinesAsCollection,
+ bBestEffort,
+ bAutoClose,
+ dfTolerance,
+ peErr );
+ CPL_C_END
OGRPolygon *OGRBuildPolygonFromEdges( OGRGeometryCollection * poLines,
int bBestEffort,
int bAutoClose,
