[Gdal-dev] Small issue with SetUTM()
VTP ben at vterrain.org
Tue Apr 1 10:39:24 EST 2003
Thanks Frank, the workaround you indicate is perfectly good.
-Ben
> -----Original Message-----
> From: Frank Warmerdam
> Sent: Tuesday, April 01, 2003 9:33 AM
> To: gdal-dev at remotesensing.org
> Subject: Re: [Gdal-dev] Small issue with SetUTM()
> An application wanting SetUTM() to also set a name could call
> SetNode("PROJCS","unnamed") initially to ensure SetUTM() will set the name
> to something nice.
> I will clarify the SetUTM() documentation, but not change the behaviour.
