[Gdal-dev] Re: OGR Questions
Frank Warmerdam
warmerdam at pobox.com
Tue Apr 8 17:20:52 EDT 2003
Peter Lenson wrote:
> Hi Frank,
> As usually we need this ASAP.
> To clarify what we want to do is readin the
> shapefile into memory, have the ability to add
> fields to this memory representation. Make use
> of this memory representation for drawing.
> And finally save this memory representation
> to disk.
Peter,
I have committed a bunch of changes implementing a new "Memory" type
OGR driver that supports adding fields when the layer already has features.
I also implemented an "easy copy" API for copying layers.
Included below is a simple C++ example utilizing the new capabilities. I
have taken the liberty of cc:ing the gdal-dev list. You might want to
introduce your project to the list at some point.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
#include <assert.h>
#include "ogrsf_frmts.h"
int main( int nArgc, char **papszArgv )
OGRDataSource *poSrcDS, *poMemDS, *poDstDS;
OGRSFDriver *poDriver;
/* Open the source file. */
OGRRegisterAll();
poSrcDS =
OGRSFDriverRegistrar::GetRegistrar()->Open( "polygon.shp" );
assert( poSrcDS != NULL );
/* Copy this to a datasource using the "Memory" driver ... all */
/* in memory. */
poDriver =
OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName( "Memory" );
assert( poDriver != NULL );
poMemDS = poDriver->CopyDataSource( poSrcDS, "polygon.shp", NULL );
delete poSrcDS;
/* Add a new field to the first layer in the datasource. */
OGRFieldDefn oNewField( "StyleInfo", OFTString );
oNewField.SetWidth( 64 );
poMemDS->GetLayer( 0 )->CreateField( &oNewField );
/* we could do lots of stuff with our in-memory data here */
/* Save back to disk in a new file. */
poDriver =
OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName( "ESRI Shapefile" );
poDstDS = poDriver->CopyDataSource( poMemDS, "polynew.shp", NULL );
delete poMemDS;
delete poDstDS;
delete OGRSFDriverRegistrar::GetRegistrar();
