[Gdal-dev] gdalwarp: bad output header?
Michael Tan
mdtanxp at myrealbox.com
Fri Apr 11 17:47:04 EDT 2003
Hi-
I am trying to reproject a UTM GeoTIFF to an LatLon GeoTIFF. gdalwarp
seems to do it, but does not seem to produce a correct header (which I
need to determine the lat-lon coords for the corners).
Here's my output:
> gdalwarp --version
GDAL 1.1.8.0, released 2002/12/21
> gdalwarp -t_srs "+proj=latlong +datum=WGS84" p174r38_5t870814_nn2.tif
ll2.tif
Creating output file is that 8659P x 7325L.
:0...10...20...30...40...50...60...70...80...90...100 - done.
> gdalinfo ll2.tif
Driver: GTiff/GeoTIFF
Size is 8659, 7325
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 7325.0)
Upper Right ( 8659.0, 0.0)
Lower Right ( 8659.0, 7325.0)
Center ( 4329.5, 3662.5)
Band 1 Block=8659x1 Type=Byte, ColorInterp=Gray
Am I doing something wrong?
Thanks.
Michael
