[Gdal-dev] gdalwarp: bad output header?
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 11 18:03:49 EDT 2003
Michael Tan wrote:
> Hi-
> I am trying to reproject a UTM GeoTIFF to an LatLon GeoTIFF. gdalwarp
> seems to do it, but does not seem to produce a correct header (which I
> need to determine the lat-lon coords for the corners).
Michael,
I am not sure what is going wrong. This _can_ work since I just tried it
without a problem:
warmerda at gdal2200[18]% gdalwarp -t_srs "+proj=latlong +datum=WGS84" openev/utm.tif out.tif
Creating output file is that 558P x 466L.
:0...10...20...30...40...50...60...70...80...90...100 - done.
warmerda at gdal2200[19]% gdalinfo out.tif
Driver: GTiff/GeoTIFF
Size is 558, 466
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-117.642054,33.903651)
Pixel Size = (0.000597,-0.000597)
Corner Coordinates:
Upper Left (-117.6420540, 33.9036511) (117d38'31.39"W, 33d54'13.14"N)
Lower Left (-117.6420540, 33.6252533) (117d38'31.39"W, 33d37'30.91"N)
Upper Right (-117.3086936, 33.9036511) (117d18'31.30"W, 33d54'13.14"N)
Lower Right (-117.3086936, 33.6252533) (117d18'31.30"W, 33d37'30.91"N)
Center (-117.4753738, 33.7644522) (117d28'31.35"W, 33d45'52.03"N)
Band 1 Block=558x14 Type=Byte, ColorInterp=Gray
warmerda at gdal2200[20]%
What version of GDAL are you using? What did the coordinate system info on
the source file look like? The gdalinfo report on the source should
be sufficient.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
