[Gdal-dev] Exception thrown in GDALOpen() function
Sat Aug 2 21:28:30 EDT 2003
Ben Discoe wrote:
> Noureddine,
> It is quite likely that you are using the debug-mode GDAL with your
> release-mode applications, or vice-versa.  They must match.  This means
> that in order to develop application in both debug and release mode, you
> need to build GDAL both ways.
Ben,
Could you clarify why non-debug applications can't use debug versions of
the library and the other way around?  It seems to me I often do this myself
without problems.  Is it some difference in calling conventions or something
like that?
Best regards,
