[Gdal-dev] LIDAR to DEM
Ben Discoe
ben at vterrain.org
Fri Aug 8 11:33:40 EDT 2003
Christoph,
It is better to describe what software system you will want to read the
LIDAR data into. If you mean "USGS DEM", it is not a transfer format,
however there are other kinds of "DEM" that we can recommended based on
your exact needs.
-Ben
> -----Original Message-----
> From: Christoph Spoerri
> Sent: Friday, August 08, 2003 10:22 AM
> To: gdal-dev at remotesensing.org
> Hi List,
> I was wondering if it's possible to convert LIDAR images to
> DEMs with the GDAL
> library. If not, how difficult would it be to write some code
> that does this?
> Thanks,
> Christoph
