[Gdal-dev] LIDAR to DEM
Christoph Spoerri
spoerri at duke.edu
Fri Aug 8 11:45:55 EDT 2003
Ben,
I'm not quite sure yet, since I'm just scoping out some possebilities for a
potential project for a client. I know, they want to use the DEMs with the
SWAT modeling software (I guess the ArcView version, since they don't know
about GRASS).
Thanks,
Christoph
On Friday 08 August 2003 11:33 am, Ben Discoe wrote:
> Christoph,
> It is better to describe what software system you will want to read the
> LIDAR data into. If you mean "USGS DEM", it is not a transfer format,
> however there are other kinds of "DEM" that we can recommended based on
> your exact needs.
> -Ben
> > -----Original Message-----
> > From: Christoph Spoerri
> > Sent: Friday, August 08, 2003 10:22 AM
> > To: gdal-dev at remotesensing.org
> > Hi List,
> > I was wondering if it's possible to convert LIDAR images to
> > DEMs with the GDAL
> > library. If not, how difficult would it be to write some code
> > that does this?
> > Thanks,
> > Christoph
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
