[Gdal-dev] vector to raster conversion
Frank Warmerdam
warmerdam at pobox.com
Wed Aug 27 12:31:48 EDT 2003
Brian Marchand wrote:
> Hello,
> I know there are many GIS savvy people on this list and I was wondering
> if anyone knew of any vector to raster conversion code that is floating
> around. My interest is in converting elevation data stored in shape
> files to any elevation raster format supported by GDAL.
Brian,
I assume what you have is contour and possibly breakline information? Or
is it point elevations? Building a decent raster DEM from contours and
breakline information is not a trivial process. I worked on some algorithms
for it at PCI but I am not aware of anything directly available built on GDAL.
You could use commercial software, like PCI. I also think there may be a
decent contour to raster program in GRASS but I am not sure.
If you just have point data, any point interpolator would likely do, such as
the one in OpenEV mentioned by Tyler.
MapServer is good for a variety of rasterization issues, but it isn't an
interpolator.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
