[Gdal-dev] CPLReadLine problem on windows platforms
Fri Aug 29 13:35:01 EDT 2003
Roger James wrote:
> Frank,
> CPLReadLine has a problem on windows platforms when passed a file
> pointer that has been opened in text mode. The underlying removal of
> carriage return characters by wijndows causes the fseek positioning to
> be wrong.
> This causes world file parsing to be wrong. My temp fix is in the above
> snippet. I do not know if there are other places where this fix is need
> or if it causes any side affects. But I can read jgw files on windows now J
Roger,
I see what you mean, and I have changed CSLLoad() to use the binary file type
when opening the file.  I am surprised this hasn't come up more.  Andrey is
also doing something recently with a CPLFGets() ... I don't know if this
could be related or not.
> I have a vague recollection about reporting this or a similar bug many
> moons ago.
Hmm, I don't recall my I have a very lossy memory.
Best regards,
