[Gdal-dev] Windows OpenEV HDF PB
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 29 14:49:19 EDT 2003
Julien Demaria wrote:
> Hello,
> I try GDAL today with OpenEV_FW under Windows (OpenEV_FW version 1.6.2)
> and Linux (OpenEV_FW version 1.5.4) platforms.
> I have problems with this HDF4 file only with the Windows version (1.6.2) :
> [] /users/dem/tmp/openev_FW/bin > gdalinfo
> /obe-temp/dem/S19981822003212.L3m_MC_CHLO.hdf
> Driver: HDF4Image/HDF4 Dataset
> Size is 4096, 2048
> Coordinate System is `'
> Origin = (0.000000,0.000000)
> Pixel Size = (1.000000,1.000000)
> Corner Coordinates:
> Upper Left ( 0.0000000, 0.0000000)
> Lower Left ( 0.000, 2048.000)
> Upper Right ( 4096.000, 0.000)
> Lower Right ( 4096.000, 2048.000)
> Center ( 2048.000, 1024.000)
> Band 1 Block=4096x1 Type=Byte, ColorInterp=Gray
> under linux all works very well, but on Windows when I try to import or
> open the file python.exe fails (I have a Windows popup with "cannot read
> memory at ...") and all OpenEV is closed...
> Maybe it's a bug between 1.5.4 and 1.6.2 version or a GDAL HDF bug under
> Windows ?
Julien,
It could be either of those. Would it be possible to make the file available
somewhere for Andrey or I to try out?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
