[Gdal-dev] A questions about IRasterIO and overlays
gdal-dev-admin at remotesensing.org
Tue Dec 9 14:50:50 EST 2003
gdal-dev-admin at remotesensing.org wrote:
> Hmmm - remote subsetting is kinda what the OpenGIS web coverage server spec, http://www.opengis.org/docs/03-065r6.pdf, and the JPEG2000 JPIP protocol, http://www.kakadusoftware.com/jpip-links-and-info.html, are all about...
> It would be awesome if someone were psyched to implement one of these items as a GDAL driver!
Chris,
It is my hope to at some point build WMS and WCS client support right
within GDAL at which point I will face similar issues to what James is
running into with OPeNDAP. I would likely take the approach I outlined.
I would add that I made a first crack at being able to use JPIP in the
JP2KAK driver. There, I used the same IO strategies used with local files
and I think this resulted in pretty terrible performance in some cases.
But I also found the whole JPIP access very flakey. I presume this was
due to a poor implementation on my part, but I never had any client requesting
JPIP support, so I let it drop.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
