[Gdal-dev] arcinfo grid gotcha
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Dec 9 19:57:10 EST 2003
Hi all,
Stumbled across a "gotcha" this afternoon when using the Windows gdal
utilities v1.1.8 (from openev_fw distribution) and ArcInfo binary grids
(v1.1.9 info at end):
* If you type a trailing slash, the internal AIG grid driver is used.
* If you omit the slash, the external GIO driver is used.
* Because the two drivers have different abilities, the output may not
be what you expect. In particular the number format (byte, int32, etc)
and projections are different (or absent).
* It doesn't seem to matter which slash is used (\ or /).
> gdal_translate arcinfo_grid/ aig.tif
> gdalinfo aig.tif
Driver: GTiff/GeoTIFF
Size is 6927, 6799
Coordinate System is:
PROJCS["unnamed",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["standard_parallel_1",61.66666666666666],
PARAMETER["standard_parallel_2",68],
PARAMETER["latitude_of_center",59],
PARAMETER["longitude_of_center",-132.5],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",500000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (183318.249099,624474.799031)
Pixel Size = (17.490628,-17.490628)
Corner Coordinates:
Upper Left ( 183318.249, 624474.799) (138d10'18.18"W, 59d59'32.80"N)
Lower Left ( 183318.249, 505556.021) (137d59'16.23"W, 58d55'35.54"N)
Upper Right ( 304475.828, 624474.799) (136d 0'27.34"W, 60d 4'16.47"N)
Lower Right ( 304475.828, 505556.021) (135d53'36.67"W, 59d 0'10.44"N)
Center ( 243897.038, 565015.410) (137d 0'54.78"W, 59d30'11.08"N)
Band 1 Block=6927x1 Type=Byte, ColorInterp=Gray
NoData Value=255
> gdal_translate arcinfo_grid gio.tif
> gdalinfo gio.tif
Size is 6927, 6799
Coordinate System is `'
Corner Coordinates:
Band 1 Block=6927x1 Type=Int32, ColorInterp=Gray
NoData Value=-2.14748e+009
With gdal 1.1.9 compiled under cygwin only the GIO driver is used, with
or without a trailing slash. This is undesirable because the AIG driver
is superior, at least with the data we use. (Presumably one could
compile v119 without GIO). Is there a mechanism to force which driver is
used to read the source data set?
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
