[Gdal-dev] arcinfo grid gotcha
Frank Warmerdam
warmerdam at pobox.com
Wed Dec 10 09:06:59 EST 2003
Matt Wilkie wrote:
> With gdal 1.1.9 compiled under cygwin only the GIO driver is used, with
> or without a trailing slash. This is undesirable because the AIG driver
> is superior, at least with the data we use. (Presumably one could
> compile v119 without GIO). Is there a mechanism to force which driver is
> used to read the source data set?
Matt,
From within a program you can use GDALDriverManager::DeregisterDriver()
to remove the GIO driver.
Users can set the GDAL_SKIP environment variable with a list of space
seperated driver names that they wish to not be used.
eg.
set GDAL_SKIP="GIO"
gdalinfo mygrid
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
