[Gdal-dev] A questions about IRasterIO and overlays
James Gallagher
jgallagher at gso.uri.edu
Fri Dec 12 14:06:24 EST 2003
On Tue, 2003-12-09 at 11:19, gdal-dev-admin at remotesensing.org wrote:
> James Gallagher wrote:
> > I'm improving a GDAL driver for the DODS/OPeNDAP protocol. The driver
> > can read rasters from DODS/OPeNDAP servers. One problem with the current
> > implementation is that it always reads the entire raster.
> > Before I dive into IRasterIO() I'd like to make sure providing my own
> > implementation of that method is really the best way to go. OPeNDAP
> > provides ways to read parts of rasters using the indexes combined with
> > an optional 'stride' value (which allows for sub-sampling).
> > I was also wondering about overlays and the comment that a driver that
> > provides its own implementation of IRasterIO() would normally implement
> > overlays. What exactly are 'overlays?'
> > As you can probably tell, I'm not that familiar with GIS software so my
> > apologies if these are really basic questions.
> James,
> I'm not sure where you read overlays. I suspect you are referring to
> overviews, is that correct?
Yes. Sorry about that.
> An overview is a reduced resolution image used
> for faster reads when only a reduced resolution image is needed.
> You can use stride values to simulate overviews. So, I think it would
> be wise to return synthetic power of 2 overiews for your dataset. You might
> want to skim the MrSID example for how this can be done.
> However, the deeper problem is how to handle IO requests. Right now I gather
> you read the whole remote dataset on open, and pull it into local memory?
No, but almost. The DAP provides a pretty rich set of sub-sampling
tools. What I do now is read 'metadata' in when the remote data source
is opened. Then I use that to build RasterBand instances. When the drver
is used to get data from a particular RasterBand I read the data. But,
and it's a big but, the DAP lets a client do things like read just a
portion of an array and right now I'm ignoring that. The driver always
reads the entire Array. In many ways reading just part of an Array is an
optimization since most of the data sources in DODS (i.e., accessible
using DAP servers) holds more than one Array. So being able to read just
the Array the client wants instead of the whole data source is a big
win. But, of course, we want the whole enchilada...
> For modest sized datasets that are read by applications a bit at a time this
> is a very good approach. I would presume there is a non-trivial overhead
> (network latency, etc) to each OPeNDAP request?
Yes, there is, although the middleware library does support client-side
caching.
> If network latency and other request overhead was zero,the idea approach would
> be to satisfy each IRasterIO() request with an OPeNDAP request. This would
> minimize the amount of memory used in the driver, and ensure only required
> data would be read. However, there is latency, and for some sorts of requests,
> such as the common case of the application asking for the entire dataset, but
> one scanline at a time, the latency would likely kill you.
Good point about the one-scanline-at-a-time issue. Maybe it's best we
read the entire array at once...
> On the other hand if you are working with a big dataset, and a client like
> MapServer that might only want a small area or want the dataset at a much
> reduced resolution, then reading the whole thing will kill you.
Yup.
> What I have done in some drivers is have two basic cases:
> 1) Attempt to satisfy each RasterIO() request via a lower level request.
> 2) Treat the dataset as "scanlined organized" for blocksize/caching
> purposes, but read-ahead lots of scanlines in response to any request
> that isn't satisfied out of the cache. Implement this logic in the
> IReadBlock() method.
> then I basically check the nature of the request in the RasterIO() to
> decide how to handle it. If the request is fairly large then I stick
> with case (1) otherwise I call the GDALRasterBand::IRasterIO() which will
> eventually call IReadBlock() taking care of any required resampling.
> I hope this helps, though I am proposing some complications. :-)
It does help (although it does pose some complications!).
Thanks very much,
James
> Best regards,
__________________________________________________________________________
James Gallagher The Distributed Oceanographic Data System
jgallagher at gso.uri.edu http://unidata.ucar.edu/packages/dods
Voice/Fax: 406.723.8663
