[Gdal-dev] gdal_translate
Ayman Kamal
kamal_jo at yahoo.com
Sun Feb 16 06:17:32 EST 2003
I sent u a message explainig what do I specifically
need :
building a stand alone application that can open a
GeoTiff file and convert it to a BMP file, that's all.
I don't know if I need to use GDAL library or OpenEV,
can u tell me what do u I need specifically to do
this, and where can I find the source of OpenEV ( the
application ) so that I can see what is going on.
Thanks
--- Andrey Kiselev <dron at ak4719.spb.edu> wrote:
> On Sun, Feb 16, 2003 at 02:21:03AM -0800, Ayman
> Kamal wrote:
> > Thanks for your help, but here is my situation:
> > I am using Microsoft Visual Studio, and I want to
> be
> > able to create and build a project ( application )
> > that does the same as what gdal_translate. Simply
> I
> ...and this application will be based on GDAL?
> > want to know what do I need to accomplish this
> task
> > whether regarding needed files or other settings.
> I
> > want my application to be a stand alone
> application
> > along with the files needed with it.
> Anyway, take the sources and build the library. Then
> you should point
> to compiler where the header files and compiled
> binary placed. You can
> look at the OpenEV sources for the sample, how to
> use GDAL in external
> project. Use makefile.vc from the OpenEV as a
> template.
> Andrey V. Kiselev
> Home phone: +7 812 5274898 ICQ# 26871517
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
__________________________________________________
Do you Yahoo!?
Yahoo! Shopping - Send Flowers for Valentine's Day
http://shopping.yahoo.com
