[Gdal-dev] gdal_translate
    Ayman Kamal
    kamal_jo at yahoo.com
    Sun Feb 16 10:28:19 EST 2003
Sir,
what I ask for is only the following:
I want to be able to build and execute gdal_translate
as a standalone project. I am using Microsoft Visual
Studio 6.0 IDE. What header files do I have to put in
the application directory and what library files do I
need to put in my workspace, and what DLLs do I have
to put in the same path of the EXE file so that the
application can survive alone.
--- Ed McNierney <ed at topozone.com> wrote:
> Ayman -
> As Andrey said, this is easy to do once you have a
> GDAL build set up.  I
> have found Frank's Windows makefiles very nicely
> arrange and easier than
> most Open Source tools to build under Windows.
> Have you downloaded the GDAL distribution?  If not,
> do so.  Then build
> it.  When you get to the point where you can build,
> say, gdal_translate
> in the apps directory, you're ready to go.  The GDAL
> download and build
> instructions are all available on the GDAL site at
> http://www.remotesensing.org/gdal
> Once you're at that point, we can get going!
> 	- Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA  01863
> Phone: (978) 251-4242  Fax: (978) 251-1396
> ed at topozone.com
> -----Original Message-----
> From: Ayman Kamal [mailto:kamal_jo at yahoo.com]
> Sent: Sunday, February 16, 2003 8:04 AM
> To: gdal-dev at remotesensing.org
> Subject: Re: [Gdal-dev] gdal_translate
> what I need is a list of the
> .h files
> .lib files
> .dll files
> that I need to include in my project to be able to
> write a simple Win32 console application that can
> convert a GeoTiff file format into BMP file forma.
> That's all
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Shopping - Send Flowers for Valentine's Day
> http://shopping.yahoo.com
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
Do you Yahoo!?
