[Gdal-dev] gdal_translate
Ed McNierney
ed at topozone.com
Sun Feb 16 12:16:42 EST 2003
Have you read apps/makefile.vc and nmake.opt?
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242 Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
Sent: Sunday, February 16, 2003 10:49 AM
To: gdal-dev at remotesensing.org
Subject: RE: [Gdal-dev] gdal_translate
I want to use it as a statically linked library.
Can you give me more explanation building apon this
fact?
--- Ed McNierney <ed at topozone.com> wrote:
> Ayman -
> If you followed my suggestions you would find the
> answer to those
> questions.
> If you need to create a Microsoft Visual Studio
> project, you will need
> to do that yourself as it's not part of the GDAL
> distribution.
> If you read the makefile.vc file in the apps
> directory, where
> gdal_translate lives, you'll find exactly the header
> files and libraries
> it uses. You'll also need to look at the nmake.opt
> options file in the
> root GDAL directory; the answer to your question
> depends (slightly) on
> whether you intend to use GDAL as a DLL or
> statically linked.
> - Ed
> Ed McNierney
> ed at topozone.com
> From: Ayman Kamal [mailto:kamal_jo at yahoo.com]
> Sent: Sunday, February 16, 2003 10:28 AM
> Sir,
> what I ask for is only the following:
> I want to be able to build and execute
> gdal_translate
> as a standalone project. I am using Microsoft Visual
> Studio 6.0 IDE. What header files do I have to put
> in
> the application directory and what library files do
> I
> need to put in my workspace, and what DLLs do I have
> to put in the same path of the EXE file so that the
> application can survive alone.
> > Ayman -
> > As Andrey said, this is easy to do once you have a
> > GDAL build set up. I
> > have found Frank's Windows makefiles very nicely
> > arrange and easier than
> > most Open Source tools to build under Windows.
> > Have you downloaded the GDAL distribution? If
> not,
> > do so. Then build
> > it. When you get to the point where you can
> build,
> > say, gdal_translate
> > in the apps directory, you're ready to go. The
> GDAL
> > download and build
> > instructions are all available on the GDAL site at
> > http://www.remotesensing.org/gdal
> > Once you're at that point, we can get going!
> > - Ed
> > Ed McNierney
> > ed at topozone.com
> > Sent: Sunday, February 16, 2003 8:04 AM
> > Subject: Re: [Gdal-dev] gdal_translate
> > what I need is a list of the
> > .h files
> > .lib files
> > .dll files
> > that I need to include in my project to be able to
> > write a simple Win32 console application that can
> > convert a GeoTiff file format into BMP file forma.
> > That's all
> > __________________________________________________
> > Do you Yahoo!?
> > Yahoo! Shopping - Send Flowers for Valentine's Day
> > http://shopping.yahoo.com
> > Gdal-dev mailing list
> > Gdal-dev at remotesensing.org
> > http://remotesensing.org/mailman/listinfo/gdal-dev
> Do you Yahoo!?
Do you Yahoo!?
