[Gdal-dev] GDAL data model, caching, GDALProjDef
Derrick J Brashear
shadow at dementia.org
Sun Feb 16 14:08:37 EST 2003
On Thu, 13 Feb 2003, Frank Warmerdam wrote:
> I would actually suggest handling the image as one large TIFF file
> with tiling, pre-built overviews and deflate/zip compression. Then you
> could use the existing TIFF driver for the whole mosaic, but with similar
> performance characteristics. This assumes the result is not larger
> than 4GB.
It hadn't actually occurred to me to try this before. I do have one
question, and one unrelated question:
1) Is there a way I'm overlooking to decollar collared maps (in GeoTIFF
form) or is it expected that an external program would be used for this? I
understand that the georeferencing is insufficient to know where the image
corners are, but I have other data which can be used for this.
2) Is there a simple viewer wrapped around GDAL I can point someone at
who wants to support GDAL in an existing viewer program? (Is what's in the
"viewer" subdirectory the best option for this?)
