[Gdal-dev] large image files
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 7 09:06:11 EST 2003
Steve Brooks wrote:
> Is there an image file format that will allow images greater than 4 Gig
> in size
> and work with gdal_merge.py?
Steve,
The PAux "raw" format should work for large files (as of GDAL 1.1.8) .
> I know kakadu will compress images bigger than 4 Gig but won’t work with
> gdal_merge.py because the JP2KAKRasterBand::IWriteBlock isn’t implemented.
> Are there any plans to implement JP2KAKRasterBand::IWriteBlock?
> Would it be implemented similarly to JP2KAKCopyCreate but it would cache
> tiles
> until a complete row of tiles are available so that you can push and
> entire line
> to the compressor?
> engines[c].push(lines[c],true);
Wow ... you have done some research. There are a few issues:
o gdal_merge.py writes out a whole input file at a time. In the general
case it would not be practical to cache these till complete scanlines are
available.
o the jpeg2000 output engines require the scanlines in order, and the
bands need to be all available at the same time. This make it unsuitable
for the random access IWriteBlock() API.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
