[Gdal-dev] large image files
Steve Brooks sbrooks2 at kc.rr.com
Mon Jan 6 23:42:52 EST 2003
Is there an image file format that will allow images greater than 4 Gig
in size
and work with gdal_merge.py?
I know kakadu will compress images bigger than 4 Gig but won't work with
gdal_merge.py because the JP2KAKRasterBand::IWriteBlock isn't
implemented.
Are there any plans to implement JP2KAKRasterBand::IWriteBlock?
Would it be implemented similarly to JP2KAKCopyCreate but it would cache
tiles
until a complete row of tiles are available so that you can push and
entire line
to the compressor?
                engines[c].push(lines[c],true);
Or would there be more to it that I'm not seeing?
Thanks
Steve Brooks
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030106/d45584f3/attachment.html
